SolidCAM - CAM Software Solutions
SolidCAM CAM software is seamlessly integrated in SOLIDWORKS, Solid Edge and Inventor, with a short learning curve and powerful functionality.
SolidCAM modules include iMachining, 2.5D Milling, HSS, HSM & HSR, Sim5X, Multi-Channel Mill-Turn, Swiss Machining, Turning, Indexial 4/5 Milling and Solid Probe. Plus, SolidCAM Additive for cost effective 3D Metal Printing and efficient CNC Machining.
SolidCAM is the one-stop solution for all your CAM needs!
SolidCAM Introduces Turbo HSR
SolidCAM 2020 delivers many new features and operations, including the new Turbo HSR operation for the SolidCAM HSM/HSR module. Turbo HSR provides a new Roughing Tool Path engine with true 64-bit capability, among many other enhancements.
|  Product
SolidCAM 2020 delivers many new features and operations that enhance the CAM software platform more than ever before. In this latest release, SolidCAM’s HSM/HSR module introduces the new Turbo HSR operation
Turbo HSR provides a new Roughing Tool Path engine with true 64-bit capability, among many other enhancements including:
  • Multicore support
    With a 64-bit calculation engine, Multicore Support increases the speed of calculation as the number of cores increase. Adding ‘Toolpath Caching’ provides even faster recalculation speeds.
  • Multi-Surface Offset
    Turbo HSR Roughing allows you to define multiple surface offsets. An infinite number of groups can also be created with different surface offsets. This is very useful when machining tools and molds when flat parting surfaces are finished in the roughing stage.
  • Strategies
    Different machining patterns are available in the new Turbo HSR operation including, ‘Hatch’, ‘Contour’ and ‘Rest Roughing’.
  • Rest Rough
    Rest Roughing in Turbo 3D HSR is based on either updated stock or the previous tool that was used. The user can specify the minimum stock thickness, and the tool path is generated above it. Arc fitting in rapid moves provides smooth transitions between passes.
  • Local Stock Definition
    In Turbo HSR, local stock can be defined for the operation. The stock definition includes the undercut stock definition.
  • Fixed Collision Protection
    Collision is checked against fixtures, using either the Faces or Curves definition. The Fixture definition can be done using Faces, Part Model or Fixture Definition in Machine Setup.
  • Pre-Drilled Points
    Pre-drilled holes can now be defined for tool entry. The depth of drilling is recognized and ramping beyond the drilling depth is started automatically. This new feature is very useful for Roughing with non-center cutting tools.
  • Adaptive Feed Rate
    The new Adaptive Feed Rate function allows for constant cutting conditions – very important for maximizing tool life during Roughing.
  • Dynamic Holder Collision
    Dynamic Holder Checking provides collision free tool paths when using short tools.
  • Automatic Ramping
    Automatic Ramping makes the decision of applying Ramp Type easier with a pre-defined fall back sequence in the event that a certain style of ramping is not possible.
Contact us!
Currently there are no events
Currently there are no webinars
View Webinar Recordings
新的。SolidCAM制造商版本
全新的SolidCAM Maker版本可以让制造商、业余爱好者和学生获得SolidCAM的全部CAM功能,集成到SOLIDWORKS或Autodesk Inventor中,以制造您的个人项目。它配备了我们所有的CAM模块,包括iMachining。注册并下载全功能的SolidCAM Maker版本,该版本可免费用于私人和教育用途。
