SolidCAM - CAM Software Solutions
SolidCAM CAM software is seamlessly integrated in SOLIDWORKS, Solid Edge and Inventor, with a short learning curve and powerful functionality.
SolidCAM modules include iMachining, 2.5D Milling, HSS, HSM & HSR, Sim5X, Multi-Channel Mill-Turn, Swiss Machining, Turning, Indexial 4/5 Milling and Solid Probe. Plus, SolidCAM Additive for cost effective 3D Metal Printing and efficient CNC Machining.
SolidCAM is the one-stop solution for all your CAM needs!
Amazing iMachining saving in steel at Australian customer - 70% in Cycle time!
Saving on one part is AU$3000 - Total savings across their entire product range is incredible!
|  Drilling
Sent: Thursday, May 08, 2014 2:40 PM
To: Emil Somekh; Eddie Pevzner
Subject: Amazing iMachining saving!
Emil/Eddie,
One of our customers saved AU$3000 on only one of their parts.
They have many similar parts in their product range!
Please see details of case study:
Customer Case Study
Customer:<link http: www.wallisdrilling.com.au external-link-new-window external link in new>Wallis Drilling (Midvale, WA, Australia)
Application:iMachining
Focus of Study:Reduce cycle time (main focus on roughing)Case Study
Part: Drill Bit Body
Part Material: K1045 (UTS of 770 applied)
Batch Qty: 90 (usually 50-200 parts)
Original Toolpath Details:
Carbide tipped cutter + 16mm End Mill
Traditional 3D Roughing - maximum depth of cut 3mm
Cycle Time: 100 mins per run of 8 parts (12.5 mins per part)
Consumption of tooling:9x Carbide Inserts + 16mm End Mill (badly worn)
Cost of tooling: 9x $16 + $92 = $236
Total Machine Time:18 hours 45 mins
iMachining Toolpath Details:
12mm Carbide End Mill
2D & 3D iMachining Operations - maximum depth of cut 11.3mm
Cycle Time = 30 mins per run of 8 parts (3.7 mins per part)
Consumption of tooling = 12mm End Mill shows signs of wear but will cut more
Cost of tooling:$110 (can still be used)
Total Machine Time:5 hours 33 mins
Summary:
 Original Toolpath: 12.5 mins per part
iMachining Toolpath: 3.7 mins per part
Cycle Time saving:8.8 mins per part (a 70% saving)
Total Time saving on batch of 90:13 hours 12 mins
Total Time saving on batch of 200: 29 hours 20 mins
Example Cost saving (batch of 200): $2933 (based on hourly rate of $100)
Total Saving (including tooling):$3059 (based on hourly rate of $100)
This is only 1 drill bit of many that Wallis produce, so the total savings across their entire product range is incredible!
In applications such as this, return on investment can be achieved in a very short space of time!
Best Regards
Grant Preston
SolidCAM ANZ  | Au: <link http: www.solidcam.com.au>website<link>email0400 622 133  |  Nz: <link http: www.solidcam.co.nz>website<link>email+61 400 622 133
Contact us!
Currently there are no events
Currently there are no webinars
View Webinar Recordings
新的。SolidCAM制造商版本
全新的SolidCAM Maker版本可以让制造商、业余爱好者和学生获得SolidCAM的全部CAM功能,集成到SOLIDWORKS或Autodesk Inventor中,以制造您的个人项目。它配备了我们所有的CAM模块,包括iMachining。注册并下载全功能的SolidCAM Maker版本,该版本可免费用于私人和教育用途。
