註冊您的SolidCAM Maker版本
(MySolidCAM Maker帳戶)
SolidCAM Maker版本,帶有革命性的iMachining,提供了SolidCAM和iMachining的完整功能。
  • 無縫集成的SOLIDWORKS外掛程式 [requires valid install of standard SOLIDWORKS versions on your computer]
  • 無縫集成到 Autodesk Inventor 的附加模組 [requires valid install of Inventor on your computer]
What do you get?
After submitting the form you will receive an email with an activation link to confirm your account data. You will then be able to download the corresponding software directly from your MySolidCAM Maker account.
More information
SolidCAM User Profile Management
Edit user profile
My SolidCAM 用戶區的維護工作
My SolidCAM 用戶區目前正在修訂中,以便將來為您提供更好的用戶體驗。不幸的是,在此階段可能會出現技術問題或可用性有限。我們請求您的理解和耐心 - 謝謝!
