注册您的 SolidCAM Maker 版本
(MySolidCAM Maker 账户)
具有革命性的 iMachining 功能的 SolidCAM Maker 版本提供了 SolidCAM 和 iMachining 的完整功能,将其作为一个完整的软件包。
- 与 SOLIDWORKS 无缝集成的插件 [requires valid install of standard SOLIDWORKS versions on your computer]
- 与 Autodesk Inventor 无缝集成的插件 [requires valid install of Inventor on your computer]
What do you get?
After submitting the form you will receive an email with an activation link to confirm your account data. You will then be able to download the corresponding software directly from your MySolidCAM Maker account.
