Rob Montgomery, Mechanical Products Inc, Lombard IL, USA, “time saved is incredible”
..first part cutting steel took about 5 min using iMachining, compared to the 2-3 hrs we were spending before to make the same part
Rob Montgomery, Mechanical Design Engineer, Mechanical Products, Lombard IL http://www.mechprod.com/ "Just ran our first part cutting steel took about 5 min using iMachining compared to the 2-3 hrs we were spending before to make the same part."
"With our other CAM system we used to have to make hundreds of passes with light cuts.* Now we’re 1 inch deep with the cutter, and the time saved is incredible"
