Major saving with iMachining 3D, in both steel and aluminum, in Aircraft Industry
57% cycle time saving in Aluminum part and 76% cycle time in Steel part..
Sent: Wednesday, July 30, 2014 2:26 PM
To: Emil Somekh; Zvika Friedman
Subject: Major saving with iMachining 3D, in both steel and aluminum, in Aircraft Industry
Hello Emil,
I visited SolidCAM customer, IAI – Commercial Aircraft Group, to demonstrate the power of iMachining 3D.
We cut the first part from Aluminum 6061 with iMachining 3D
CNC Machine: Awea
Machine parameters: Spin rate: 6000  Feed :2000
Material: 6061 Aluminum
Depth of cut: 50 mm
Tool: End mill, diameter 16, teeth 3 (Hanita)
Cutting time customer: 32 minutes
iMachining Wizard: level 5 (no turbo)
Cutting time iMachining: 14 minutes (57% saving)
We cut the second part from 4340 Steel with iMachining 3D
CNC Machine: Awea
Material: 4340 Steel
Depth of cut: 24 mm
Tool: End mill, diameter 12, teeth 4 (Hanita)
Cutting time customer: 50 minutes
Cutting time iMachining: 12 minutes (76% saving)
The demonstration with iMachining 3D was watched by five people and they were all very impressed.  They asked me to give a quote for iMachining 2D and 3D.
Best Regards,
David Gontar www.solidcam.com
