iMachining savings of 60.7%
TRIAL HELD AT M/s BALAJI MACHINE TOOLS ON 21st OCTOBER 2017 ( HYDERABAD)
BENCHMARK SUMMARY
Benchmark part: LNA Housing
Total number of Settings: 1
Total number of Operations: 4
Material machined: D2 (49-53 Hrc)
Machine used: BFW-Chakra
Max rpm
Max XY Feed
Spindle Power
Controller
Material UTS
   8000
   10 m / min
     7.5 kw
Fanuc Oi-MD
   1152 mpa
Highlights of the cutting trial:
  1. Maximum depth of cut achieved on the machine in a single pass: 5 MM.
  2. Used tools Dia 4 & 3mm local carbide endmill for complete component iRoughing
  3. For iRest & iFinishing used tools Dia 3 & 2mm local carbide endmill
  4. Earlier method 3 Qty 3 & 2 End mill used
  5. Observed Increased Tool life up to 3-4 times compared to regular machining
  6. Average spindle load recorded during full depth cutting: 5-6 % when using Dia 4 Endmill , 3-4% load when using Dia 3 & 2  Endmill
Results :
Earlier Cycle Time was: 3 hrs 51 min
iMachining Cycle time: 1 hr 31 min
iMachining Cycle time Saving: 60.7%
SolidCAM User Profile Management
Edit user profile
