iMachining Saves Wuxi Turbine Blade Co. 60% in Cycle Time
SolidCAM’s engineer used iMachining 2D and decreased their roughing time from 30 minutes to 12 (60% faster) ...
SolidCAM recently visited Wuxi Turbine Blade Co., located in eastern part of China, the city of Wuxi, Jiangsu province, to run test cuts using iMachining 2D and comparing it to competitor CAM processing methods for roughing.
CNC Machine: Local Domestic 3-Axis, Spindle Power
Material: Titanium (Ti15)
Depth of Cut: 28 mm
Tool: End Mill | Diameter 20 | Nose Radius 3
Wuxi Turbine Blade’s Previous Cutting Time: 30 minutes
iMachining Cutting Parameters: Level 3
iMachining Cutting Time: 12 minutes
iMachining Savings: 60% Cycle Time Reduction iMachining’s Technology Wizard automatically calculates the optimal feeds & speeds based on the CNC machine, Tool and Material.
While using the competitor CAM for roughing, the machine was running below 1000 rpm. When Wuxi Turbine Blade used iMachining, the machine was running above 3000 rpm.
