iMachining cycle time saving of 80%
Benchmark at Sri Skandha Pvt Ltd - Bangalore
TRIALS CONDUCTED ON 27TH APRIL 2018
BENCHMARK SUMMARY
1. Benchmark component               : ROTOR PLATE
2. Total number of Settings            : 1
3. Total number of Operations       : 2 Operations
4. Total Machining Time                  : 1 Hrs 23 Min
5. Material machined                       : E 250
6. Machine used for Cutting Trial   : BFW BMV 60
Max rpm
Max XY Feed
Spindle Power
Controller
Material UTS
8000
   10 m / min
     7.5 kw
BFW BMV 60
   450 Mpa
Highlights of the cutting trial:
1. Maximum depth of cut achieved on the machine in a single pass: 22 MM.
2. No bending or warpage found even after cutting 22 MM deep.
3. Average spindle load recorded during full depth cutting: 18%
4. All the operations were done using full flute length of the cutter.
Results :
1. Earlier Cycle Time was                             :   6 Hrs 3 Min.
2. iMachining time                                        :   1 Hrs 23 Min.
3. Difference                                                 :   4 Hrs 40 Min.
4. Cycle time Saving                  :   80%
