Special iMachining Story – great success at Carl Zeiss SMT
..now the manager was deeply convinced to change his current CAM software.
iMachining 3D + HSM Finish Results – Fantastic!
Finish achieved was 0.37 Ra Value, which is about half of what was expected!!!
SolidCAM with iMachining demolishes Competitor CAM
..65% cycle time saving.. Phenomenal tool life.. Excellent finish..
Major cross upgrade of competitor CAM because of 80% saving in SolidCAM iMachining!!
…With the first iMachining cutting attempt, the tool was running very quiet and smooth in a safe process.
Important saving in cutting magnesium part with SolidCAM iMachining vs Competitor CAM
Machining time reduced from 25 hrs in Competitor CAM to 16 hrs in SolidCAM iMachining..programming time also reduced by 1 hr
Nate Stuart, 034motorsport: “Absolutely loving iMachining, or rather my operator is!”
…he’s always impressed how quickly we’re chewing new parts thanks to it – it cut our steel times way down, and tool life is way up.. the times are dramatically reduced..
Cutting part with iMachining 3D saves cycle time and extends tool life dramatically!
….33% saving in cycle time.. ISCAR Tool cut 12 Parts with iMachining 3D toolpath, instead of only 1 Part with Competitor CAM!
iMachining win against Competitor – 10 min vs 33 min..
..He said to me : “iMachining is unbelievable – it really works very well. This is the first time I see something like that”
Finding Optimal Feeds and Speeds: “Other CAM programs are light years behind iMachining.”
..I have yet to see a CAM program that has very good speeds and feeds built in with the possible exception of SolidCAM’s iMachining
iMachining vs. Competitor in Aluminum cutting – totally superior, completely another level!
..cutting this part in 20 min with your CAM system and I’m cutting it with iMachining in 6 min.
Jason Near, Rotary Airlock, LLC, Rock Falls, IL, USA “Every day we don’t use SolidCAM iMachining we are losing money!”
“You can quickly recover the entire cost of SolidCAM and iMachining in tooling cost savings alone.”
iMachining at Maini Aerospace – 58% Savings in Aluminum against Competitor CAM
…Competitor CAM – 200 min, iMachining – 84 mins
Successful cutting trial at Ducom on Magnesium Grade AZ31B-H24 – iMachining saves 65% in Machining time
..customer was using another CAM system & desperately looking for reduction in machining time with safe toolpath
iMachining at Adin – replacing competitor CAM after 52% saving in steel
..material is steel 4140, and they need to supply 600 pieces…plant manager decided to purchase SolidCAM+iMachining
iMachining smokes fire out of Competitor CAM software
… manager accepted that it was a mistake in believing his programmer that the Competitor CAM had a similar option and accepted that iMachining is unique.
Great iMachining win against Competitor CAM – drastically reduced the machining time.
…the father who founded the business, 83-year old and still active, said “He who does not buy iMachining is mad!”
