With Patience, iMachining Eventually Wins!
Golan Industries is a northern plant of Israel Aerospace Industries (IAI). The factory has been producing aviation parts, especially aircraft seats, and has been programming its parts with SolidCAM software for many years.
iMachining cycle time saving of 80%
Benchmark at Sri Skandha Pvt Ltd – Bangalore
SolidCAM iMachining win at M/s SHAKAMBARI INDUSTRIES
Shakambari Industries is a small Aerospace components manufacturing company.
iMachining Success at SolidCAM Customer – 78% Cycle Time Savings …
Trials held at M/s Grace Infrastructure on November 18th, 2017.
Time savings with iMachining and the wide variety of CAM modules in SolidCAM helped to meet customer’s production requirements
CAM SYSTEMS, SolidCAM Reseller in Russia, visited Research and Production Company Sistema (http://tversystema.ru), located in Tver’ city (200 km to the north of Moscow).
SolidCAM and iMachining take part in the manufacture of Škoda Fabia R5
…after only two months, iMachining had returned its investment! The main savings were in machining time, which were cut in half in many cases, compared to standard milling strategies….
iMachining 3D + HSM Finish Results – Fantastic!
Finish achieved was 0.37 Ra Value, which is about half of what was expected!!!
iMachining 2D win at customer Sustiel – 64% saving in Aluminum…
Time saved on the amount of 250 parts : 18 hours
SolidCAM with iMachining demolishes Competitor CAM
..65% cycle time saving.. Phenomenal tool life.. Excellent finish..
iMachining great success on a Mill-turn Okuma Multus machine.. 58% saving on turbine blade.
…I used iMachining 2D &3D and the cutting time at the end was 34 min, down from original 80 min, which is far beyond the end user’s expectations (58% saving).
Major saving with iMachining 3D, in both steel and aluminum, in Aircraft Industry
57% cycle time saving in Aluminum part and 76% cycle time in Steel part..
iMachining great success at AH Industries
iMachining is the module they use now for all Roughing operations in the machine shop, for all kind of materials, for all kind of pockets, profiles and 3D roughing operations.
iMachining Success at MWE in stainless steel – 76% savings!
..The boss of the company says – that looks like we are working with aluminum!!!
iMachining win at El AL – 65% saving in cycle time in steel ..
..very impressed with the results, the speed of processing and the smooth cutting.
Greg Burns, Burns Machinery Inc. on SolidCAM & iMachining
SolidCAM & iMachining had the quickest return on Investment on anything of significance that I put money into in the last 10 years! What we saved in first month on tool life, paid for the software!
Major cross upgrade of competitor CAM because of 80% saving in SolidCAM iMachining!!
…With the first iMachining cutting attempt, the tool was running very quiet and smooth in a safe process.
Amazing iMachining saving in steel at Australian customer – 70% in Cycle time!
Saving on one part is AU$3000 – Total savings across their entire product range is incredible!
iMachining Success at important Aircraft parts company
Show them iMachining live on their machine – cut one big Titanium part – result was really good. They make parts for Civilian & Military Aircraft, Space Rockets..
3D iMachining WIN in steel – 81% savings
Reduced cutting time from 146 min to 28 min! They were very impressed by the ease and speed of programming of the part..
Important saving in cutting magnesium part with SolidCAM iMachining vs Competitor CAM
Machining time reduced from 25 hrs in Competitor CAM to 16 hrs in SolidCAM iMachining..programming time also reduced by 1 hr
iMachining 2D customer is impressed with iMachining 3D results
The results with iMachining 3D were of course much better than whatever they imagined.
iMachining 3D live cutting at Thai Vacuum molding customer – 85% saving in steel…
..Workshop owner could not believe his eyes.
iMachining 3D Success at Micon – 59% saving in steel
Former Milling Time over 24 hours for all 5 Pockets – iMachining 3D time is about 10 hours..
iMachining saving in Aluminum reaches 75%
..”It was just amazing – iMachining worked immediately – For all components, we now achieve savings of 65 to 75%.”
iMachining 2D & 3D impressive results cutting steel and titanium
“It is incredibly impressive seeing iMachining cutting stainless steel 1.4301 – we would have never thought such results were possible”.
Saving 65% in cutting aluminum part with iMachining 2D, at SolidCAM customer Terlidor
..total cycle time saving for the 400 piece series: 73 hr 20 min..
iMachining 3D saves customer 48% in cycle time in aluminum
…after iMachining 2D increased his profit by 300% when cutting steel!
iMachining + HSM cutting Aluminum – 33% saving in cycle time, double tool life, reduce programming time
..reducing machining time from 15 min to 10 min per part.. and from 2 end mills to 1 end mill..
Saving 80% cycle time, cutting titanium with iMachining 2D
..total saving for 75 parts: 16 hr 52 min.. customer was completely excited and amazed
Great win for iMachining in Aluminum – 64% saving!
..they did not believe that we can cut with the full depth of the tool and with the milling speeds generated by iMachining..
iMachining success with special Tool from Mapal
…iMachining was very successful with this part, working really well – fast, controlled and machining gently.
Nate Stuart, 034motorsport: “Absolutely loving iMachining, or rather my operator is!”
…he’s always impressed how quickly we’re chewing new parts thanks to it – it cut our steel times way down, and tool life is way up.. the times are dramatically reduced..
Cutting part with iMachining 3D saves cycle time and extends tool life dramatically!
….33% saving in cycle time.. ISCAR Tool cut 12 Parts with iMachining 3D toolpath, instead of only 1 Part with Competitor CAM!
Huge aluminum part cut with SolidCAM, mainly with iMachining..
..aluminum part for Bloodhound SSC, which is a jet and rocket powered car designed to go at 1,000 mph and is a mix of car and aircraft technology…
iMachining 3D benchmark in Cadron Aviation: saving 56% in cycle time, cutting deep in Aluminum
The programmer could not believe that even though they have to fix the part with vacuum fixation, the part can be cut at such high speed.
iMachining success – cycle time reduction by 70% against Competitor CAM in Aluminum
..prospect working with Competitor CAM and wanted to change for a CAM solution integrated in SolidWorks… impressed to see how easy it was to machine his part with iMachining in such a short time and get a such good result at the first try
SolidCAM customer A.P.A orders 2 modules of iMachining 2D and 3D, mainly for aluminum machining
..owner said: “amazing… I have no words to describe my satisfaction from iMachining – I couldn’t have imagined how much time it saved us in Aluminum”
Jeff S.: “iMachining is incredible at removing large amount of material in hard to reach areas such as the magwell and fire control pockets.”
…thanks to the InventorCAM team, in 3 months time I have learned to run a Haas VF3SS and a rudimentary CAM program without any CNC background
iMachining amazes customer with its outstanding capability in cutting steel, on an old CNC machine!
..customer extremely impressed – could not believe that these feeds and speeds are possible for such a machine!
Terence Sammon, Mico Industries, Grand Rapids, MI:”The SolidCAM software is very powerful.”
..I had some of the ‘conventionally’ trained die makers watch a block I programmed with iMachining and their jaws hit the floor when they saw how fast material could be removed on D2 tool steel!
iMachining win against Competitor – 10 min vs 33 min..
..He said to me : “iMachining is unbelievable – it really works very well. This is the first time I see something like that”
Kevin Kluver, Alexandria Industries: “It has also saved me at ton of machine time in the tooling area using the iMachining feature”
…SolidCAM is easier to use with the programming and just being able to set work coordinates faster and much easier
iMachining 3D win at Menes – 85% saving
….Chief programmer Igor said: “I hope we get such results every day – we will have great savings in costs with iMachining 3D!!”
iMachining vs. Competitor in Aluminum cutting – totally superior, completely another level!
..cutting this part in 20 min with your CAM system and I’m cutting it with iMachining in 6 min.
Amazing cutting with iMachining at EPS – Big Aluminum Electronic box – 345×175 with 115 mm depth
..the big challenge in this part was the depth, and the need to work with very long tools..
iMachining saves 66% in cutting time in Aluminum..
…iMachining of Aluminum at level 8 turbo – owner said never in his 40 years of experience in CNC, did he encounter such high speeds and depth
iMachining cut in Aluminum – 66% saving
…7 people saw the cut and filmed it -they all thought these results are impossible to achieve
Two iMachining Test Cuts at existing SolidCAM customers – savings of 66% & 75% in time
..both of them will buy iMachining..
iMachining unbelievable power brings SolidCAM customer back to subscription
..production manager so impressed with the iMachining cutting, he asked for a quote for 2 iMachining modules and renewing subscription for all their 5 SolidCAM seats..
iMachining wins against competitor CAM..saved 56 % in cycle time
..we talked to owner about iMachining – he said that he has heard that we have a module that does “miracles” but he is skeptical.
