iMachining 3D + HSM Finish Results – Fantastic!
Finish achieved was 0.37 Ra Value, which is about half of what was expected!!!
SolidCAM with iMachining demolishes Competitor CAM
..65% cycle time saving.. Phenomenal tool life.. Excellent finish..
iMachining great success on a Mill-turn Okuma Multus machine.. 58% saving on turbine blade.
…I used iMachining 2D &3D and the cutting time at the end was 34 min, down from original 80 min, which is far beyond the end user’s expectations (58% saving).
Major saving with iMachining 3D, in both steel and aluminum, in Aircraft Industry
57% cycle time saving in Aluminum part and 76% cycle time in Steel part..
iMachining great success at AH Industries
iMachining is the module they use now for all Roughing operations in the machine shop, for all kind of materials, for all kind of pockets, profiles and 3D roughing operations.
iMachining Success at MWE in stainless steel – 76% savings!
..The boss of the company says – that looks like we are working with aluminum!!!
iMachining win at El AL – 65% saving in cycle time in steel ..
..very impressed with the results, the speed of processing and the smooth cutting.
Amazing iMachining saving in steel at Australian customer – 70% in Cycle time!
Saving on one part is AU$3000 – Total savings across their entire product range is incredible!
3D iMachining WIN in steel – 81% savings
Reduced cutting time from 146 min to 28 min! They were very impressed by the ease and speed of programming of the part..
iMachining 2D customer is impressed with iMachining 3D results
The results with iMachining 3D were of course much better than whatever they imagined.
iMachining 3D live cutting at Thai Vacuum molding customer – 85% saving in steel…
..Workshop owner could not believe his eyes.
iMachining 3D Success at Micon – 59% saving in steel
Former Milling Time over 24 hours for all 5 Pockets – iMachining 3D time is about 10 hours..
iMachining 2D & 3D impressive results cutting steel and titanium
“It is incredibly impressive seeing iMachining cutting stainless steel 1.4301 – we would have never thought such results were possible”.
iMachining success with special Tool from Mapal
…iMachining was very successful with this part, working really well – fast, controlled and machining gently.
Nate Stuart, 034motorsport: “Absolutely loving iMachining, or rather my operator is!”
…he’s always impressed how quickly we’re chewing new parts thanks to it – it cut our steel times way down, and tool life is way up.. the times are dramatically reduced..
Cutting part with iMachining 3D saves cycle time and extends tool life dramatically!
….33% saving in cycle time.. ISCAR Tool cut 12 Parts with iMachining 3D toolpath, instead of only 1 Part with Competitor CAM!
iMachining amazes customer with its outstanding capability in cutting steel, on an old CNC machine!
..customer extremely impressed – could not believe that these feeds and speeds are possible for such a machine!
Terence Sammon, Mico Industries, Grand Rapids, MI:”The SolidCAM software is very powerful.”
..I had some of the ‘conventionally’ trained die makers watch a block I programmed with iMachining and their jaws hit the floor when they saw how fast material could be removed on D2 tool steel!
iMachining win against Competitor – 10 min vs 33 min..
..He said to me : “iMachining is unbelievable – it really works very well. This is the first time I see something like that”
iMachining 3D win at Menes – 85% saving
….Chief programmer Igor said: “I hope we get such results every day – we will have great savings in costs with iMachining 3D!!”
Two iMachining Test Cuts at existing SolidCAM customers – savings of 66% & 75% in time
..both of them will buy iMachining..
iMachining unbelievable power brings SolidCAM customer back to subscription
..production manager so impressed with the iMachining cutting, he asked for a quote for 2 iMachining modules and renewing subscription for all their 5 SolidCAM seats..
Rob Montgomery, Mechanical Products Inc, Lombard IL, USA, “time saved is incredible”
..first part cutting steel took about 5 min using iMachining, compared to the 2-3 hrs we were spending before to make the same part
iMachining Success story – incredible 82% saving!
..on DMC 635..material 1.2311 (40CrMnMo7)
iMachining at Adin – replacing competitor CAM after 52% saving in steel
..material is steel 4140, and they need to supply 600 pieces…plant manager decided to purchase SolidCAM+iMachining
iMachining halves cycle times and makes cutters last 5 times longer for mill-turn
..Jay Dixon realized that the SolidCAM iMachining module could make a big difference to the ease of machining on his Mazak Quick Turn Nexus
iMachining success story at SolidCAM customer – reduce time from 90 min to 8 min only!
..difficult material 1.4828 (X15CrNiSi20-12).. used in devices to inspect exhaust systems ..heat resistant up to 1000 deg..nearly no wear in tool!
iMachining smokes fire out of Competitor CAM software
… manager accepted that it was a mistake in believing his programmer that the Competitor CAM had a similar option and accepted that iMachining is unique.
