SolidCAM CAM Modules
2.5D-Milling
2.5D Milling
Create 2.5D CNC milling toolpaths with ease using full interactive control and feature recognition, offering the most powerful and efficient solution.
More Information
csm_Pocket_Recognition_C42_103_bcea4cc78a
AFRM
Experience the most powerful Automatic Feature Recognition & Machining (AFRM) system, offering unmatched efficiency and precision for your CNC milling needs.
More Information
csm_Hermle_C42_HSS_108_01_812ba62066
HSS High-Speed Surfacing
High Speed Surface Machining of Localized Surfaces
More Information
Unlock Efficiency with Indexial 4/5-Axis CNC Milling
Indexial 4/5-Axis Milling
The Most Powerful & Easiest-to-Use Coordinate System Definition
More Information
Enhance Precision with HSR & HSM 3D High-Speed Machining. Turbo HSR & Turbo HSM
HSR & HSM | 3D High Speed Machining
Powerful Roughing & Finishing Tool Paths for 3D Machining
More Information
Enhance CNC machining with SolidCAM's Turbo HSR/Turbo HSM. Accelerate roughing and finishing for faster, more productive 3D milling, reducing cycle times. Learn more here.
More Information
Simultaneous 5x Milling
SolidCAM's Proven & Powerful Simultaneous 5-Axis Machining
More Information
Solid Probe
Solid Probe
The Essential Module for Tool Setup & On-the-Spot Measurement
More Information
Turning
Turning
Program Your CNC Lathes For Fast & Efficient Turning
More Information
swiss machining - Modules overview - Mill-Turn Machining
Mill-Turn Machining
Get the Most Out of Your Mill-Turn CNC Machines
More Information
csm_STAR_SR-38_Take_2_f7497e0425
Swiss Machining
Easy Programming for Complex Multiple Turret and Multiple Spindle Swiss CNC Machines
More Information
